蚂蚁E7好控制板启动日志记录
查看1884 | 回复0 | 2024-10-20 20:43:13 | 显示全部楼层 |阅读模式
Xilinx Zynq MP First Stage Boot Loader
Release 2017.2   Apr 12 2019  -  10:22:36
Reset Mode      :       System Reset
Platform: Silicon (4.0), Cluster ID 0x80000000
Running on A53-0 (64-bit) Processor, Device Name: XCZU3EG
Processor Initialization Done
================= In Stage 2 ============
NAND Boot Mode
Manufacturer: MICRON      MT29F2G08ABAEAWP    ,
Device Model: MT29F2G08ABAEAWP    ,
Jedec ID: 0x2C
Bytes Per Page: 0x800
Spare Bytes Per Page: 0x40
Pages Per Block: 0x40
Blocks Per LUN: 0x800
Number of LUNs: 0x1
Number of bits per cell: 0x1
Number of ECC bits: 0x4
Block Size: 0x20000
Number of Target Blocks: 0x800
Number of Target Pages: 0x20000
XNandPsu_CheckOnDie: Ondie flash detected, jedec id 0x2C 0xDA
ECC: addr 0x826 size 0x1A numbits 4 codesz 9
XNandPsu_ReadBbt: Bad block table found
Nand Init Success
Multiboot Reg : 0x0
Image Header Table Offset 0x8C0
*****Image Header Table Details********
Boot Gen Ver: 0x1020000
No of Partitions: 0x5
Partition Header Address: 0x440
Partition Present Device: 0x0
Initialization Success
======= In Stage 3, Partition No:1 =======
UnEncrypted data Length: 0x153E27
Data word offset: 0x153E27
Total Data word length: 0x153E27
Destination Load Address: 0xFFFFFFFF
Execution Address: 0x0
Data word offset: 0xF590
Partition Attributes: 0x26
Destination Device is PL, changing LoadAddress
Non authenticated Bitstream download to start now
DMA transfer done
PL Configuration done successfully
Partition 1 Load Success
======= In Stage 3, Partition No:2 =======
UnEncrypted data Length: 0x1800
Data word offset: 0x1800
Total Data word length: 0x1800
Destination Load Address: 0xFFFEA000
Execution Address: 0xFFFEA000
Data word offset: 0x1633C0
Partition Attributes: 0x117
Partition 2 Load Success
======= In Stage 3, Partition No:3 =======
UnEncrypted data Length: 0x8
Data word offset: 0x8
Total Data word length: 0x8
Destination Load Address: 0xFFFF0000
Data word offset: 0x164BC0
Partition 3 Load Success
======= In Stage 3, Partition No:4 =======
UnEncrypted data Length: 0x4320E
Data word offset: 0x4320E
Total Data word length: 0x4320E
Destination Load Address: 0x8000000
Execution Address: 0x8000000
Data word offset: 0x164BD0
Partition Attributes: 0x114
Partition 4 Load Success
All Partitions Loaded
================= In Stage 4 ============
PM Init Success
Protection configuration applied
Running Cpu Handoff address: 0xFFFEA000, Exec State: 0
Exit from FSBL
U-Boot 2017.01-g67b8733-dirty (Mar 21 2019 - 04:21:17 -0700) Xilinx ZynqMP BM1794 Control Board
I2C:   ready
DRAM:  1 GiB
Relocation Offset is: 37ed3000
Relocating to 3fed3000, new gd at 3dec2de8, sp at 3dec2dd0
EL Level:       EL2
Chip ID:        xczu2eg
NAND:  256 MiB
MMC:   sdhci_send_command: MMC: 0 busy timeout increasing to: 200 ms.
sdhci_send_command: MMC: 0 busy timeout increasing to: 400 ms.
sdhci_send_command: MMC: 0 busy timeout increasing to: 800 ms.
sdhci_send_command: MMC: 0 busy timeout increasing to: 1600 ms.
sdhci_send_command: MMC: 0 busy timeout increasing to: 3200 ms.
sdhci_send_command: MMC: 0 busy timeout.
sdhci@ff170000 - probe failed: -70
** Bad device mmc 0 **
Using default environment
In:    serial@ff010000
Out:   serial@ff010000
Err:   serial@ff010000
silicon version 3
Bootmode: NAND_MODE
Net:   ZYNQ GEM: ff0d0000, phyaddr 0, interface rgmii-id
Warning: ethernet@ff0d0000 (eth0) using random MAC address - 56:28:b0:e7:02:3e
eth0: ethernet@ff0d0000
Hit any key to stop autoboot:  0
Copying Linux from NAND flash to RAM...
NAND read: device 0 offset 0x1a00000, size 0x1000000
16777216 bytes read: OK
NAND read: device 0 offset 0x2a00000, size 0x100000
1048576 bytes read: OK
Copying ramdisk...
NAND read: device 0 offset 0x2b00000, size 0x2000000
33554432 bytes read: OK
## Loading init Ramdisk from Legacy Image at 04000000 ...
   Image Name:
   Image Type:   AArch64 Linux RAMDisk Image (gzip compressed)
   Data Size:    13611444 Bytes = 13 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 03000000
   Booting using the fdt blob at 0x3000000
   Loading Ramdisk to 3d1c6000, end 3dec11b4 ... OK
   Loading Device Tree to 000000003d1ba000, end 000000003d1c5511 ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.9.0+ (fengping.shen@ubuntu) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #5 SMP Thu Mar 21 04:23:19 PDT 2019
[    0.000000] Boot CPU: AArch64 Processor [410fd034]
[    0.000000] earlycon: cdns0 at MMIO 0x00000000ff010000 (options '115200n8')
[    0.000000] bootconsole [cdns0] enabled
[    0.000000] Memory limited to 496MB
[    0.000000] efi: Getting EFI parameters from FDT:
[    0.000000] efi: UEFI not found.
[    0.000000] cma: Reserved 256 MiB at 0x000000000f000000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] percpu: Embedded 21 pages/cpu @ffffffc00ef6f000 s47384 r8192 d30440 u86016
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: enabling workaround for ARM erratum 845719
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 128518
[    0.000000] Kernel command line: earlycon clk_ignore_unused mem=496M console=ttyPS0,115200 ramdisk_size=33554432 root=/dev/ram rw earlyprintk
[    0.000000] PID hash table entries: 2048 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 65536 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 32768 (order: 6, 262144 bytes)
[    0.000000] Memory: 216584K/521200K available (9148K kernel code, 590K rwdata, 2784K rodata, 512K init, 392K bss, 42472K reserved, 262144K cma-reserved)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 GB)
[    0.000000]       .text : 0xffffff8008080000 - 0xffffff8008970000   (  9152 KB)
[    0.000000]     .rodata : 0xffffff8008970000 - 0xffffff8008c30000   (  2816 KB)
[    0.000000]       .init : 0xffffff8008c30000 - 0xffffff8008cb0000   (   512 KB)
[    0.000000]       .data : 0xffffff8008cb0000 - 0xffffff8008d43a00   (   591 KB)
[    0.000000]        .bss : 0xffffff8008d43a00 - 0xffffff8008da5c34   (   393 KB)
[    0.000000]     fixed   : 0xffffffbefe7fd000 - 0xffffffbefec00000   (  4108 KB)
[    0.000000]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 MB)
[    0.000000]     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 GB maximum)
[    0.000000]               0xffffffbf00000000 - 0xffffffbf00d8ba70   (    13 MB actual)
[    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc03dec2000   (   990 MB)
[    0.000000] Hierarchical RCU implementation.
[    0.000000]  Build-time adjustment of leaf fanout to 64.
[    0.000000]  RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] GIC: Adjusting CPU interface base to 0x00000000f902f000
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 50.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xb8812736b, max_idle_ns: 440795202655 ns
[    0.000003] sched_clock: 56 bits at 50MHz, resolution 20ns, wraps every 4398046511100ns
[    0.008233] Console: colour dummy device 80x25
[    0.012498] Calibrating delay loop (skipped), value calculated using timer frequency.. 100.00 BogoMIPS (lpj=200000)
[    0.022861] pid_max: default: 32768 minimum: 301
[    0.027532] Mount-cache hash table entries: 1024 (order: 1, 8192 bytes)
[    0.034025] Mountpoint-cache hash table entries: 1024 (order: 1, 8192 bytes)
[    0.041477] ASID allocator initialised with 65536 entries
[    0.047115] zynqmp_plat_init Power management API v0.3
[    0.052123] EFI services will not be available.
[    0.056844] Detected VIPT I-cache on CPU1
[    0.056870] CPU1: Booted secondary processor [410fd034]
[    0.057102] Detected VIPT I-cache on CPU2
[    0.057117] CPU2: Booted secondary processor [410fd034]
[    0.057343] Detected VIPT I-cache on CPU3
[    0.057359] CPU3: Booted secondary processor [410fd034]
[    0.057390] Brought up 4 CPUs
[    0.087675] SMP: Total of 4 processors activated.
[    0.092351] CPU features: detected feature: 32-bit EL0 Support
[    0.098147] CPU: All CPU(s) started at EL2
[    0.102219] alternatives: patching kernel code
[    0.106975] devtmpfs: initialized
[    0.114747] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.129211] xor: measuring software checksum speed
[    0.173861]    8regs     :  2543.000 MB/sec
[    0.213884]    8regs_prefetch:  2266.000 MB/sec
[    0.258251]    32regs    :  3126.000 MB/sec
[    0.298276]    32regs_prefetch:  2627.000 MB/sec
[    0.302700] xor: using function: 32regs (3126.000 MB/sec)
[    0.308125] pinctrl core: initialized pinctrl subsystem
[    0.313751] NET: Registered protocol family 16
[    0.334022] cpuidle: using governor menu
[    0.338009] Failed to initialise IOMMU /amba/smmu@fd800000
[    0.343501] vdso: 2 pages (1 code @ ffffff8008977000, 1 data @ ffffff8008cb4000)
[    0.350698] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.357889] DMA: preallocated 256 KiB pool for atomic allocations
[    0.373642] reset_zynqmp reset-controller: Xilinx zynqmp reset driver probed
[    0.380959] ARM CCI_400_r1 PMU driver probed[    0.386805] zynqmp-pinctrl ff180000.pinctrl: zynqmp pinctrl initialized
[    0.393470] zynqmp-pinctrl ff180000.pinctrl: Invalid IO Standard requested for pin 30
[    0.401126] zynqmp-pinctrl ff180000.pinctrl: Invalid IO Standard requested for pin 31
[    0.409163] zynqmp-pinctrl ff180000.pinctrl: Invalid IO Standard requested for pin 32
[    0.416817] zynqmp-pinctrl ff180000.pinctrl: Invalid IO Standard requested for pin 33▒[    2.990589] zynqmp-pinctrl ff180000.pinctrl: Invalid IO Standard requested for pin 32
[    2.998261] zynqmp-pinctrl ff180000.pinctrl: Invalid IO Standard requested for pin 33
▒▒r▒▒▒▒▒▒▒console [ttyPS0] enabledyPS0 at MMIO 0xff010000 (irq = 30, base_baud = 6250000) is a xuartps
[    3.015141] console [ttyPS0] enabled
[    3.022106] bootconsole [cdns0] disabled
[    3.032020] zynqmp-pinctrl ff180000.pinctrl: Invalid IO Standard requested for pin 26
[    3.039811] zynqmp-pinctrl ff180000.pinctrl: Invalid IO Standard requested for pin 27
[    3.047616] zynqmp-pinctrl ff180000.pinctrl: Invalid IO Standard requested for pin 28
[    3.055445] zynqmp-pinctrl ff180000.pinctrl: Invalid IO Standard requested for pin 29
[    3.063238] zynqmp-pinctrl ff180000.pinctrl: Invalid IO Standard requested for pin 38
[    3.071049] zynqmp-pinctrl ff180000.pinctrl: Invalid IO Standard requested for pin 39
[    3.078861] zynqmp-pinctrl ff180000.pinctrl: Invalid IO Standard requested for pin 40
[    3.086674] zynqmp-pinctrl ff180000.pinctrl: Invalid IO Standard requested for pin 41
[    3.094486] zynqmp-pinctrl ff180000.pinctrl: Invalid IO Standard requested for pin 42
[    3.102297] zynqmp-pinctrl ff180000.pinctrl: Invalid IO Standard requested for pin 64
[    3.110109] zynqmp-pinctrl ff180000.pinctrl: Invalid IO Standard requested for pin 65
[    3.117921] zynqmp-pinctrl ff180000.pinctrl: Invalid IO Standard requested for pin 66
[    3.125733] zynqmp-pinctrl ff180000.pinctrl: Invalid IO Standard requested for pin 67
[    3.133561] zynqmp-pinctrl ff180000.pinctrl: Invalid IO Standard requested for pin 68
[    3.141359] zynqmp-pinctrl ff180000.pinctrl: Invalid IO Standard requested for pin 69
[    3.149170] zynqmp-pinctrl ff180000.pinctrl: Invalid IO Standard requested for pin 70
[    3.157015] zynqmp-pinctrl ff180000.pinctrl: Invalid IO Standard requested for pin 71
[    3.164811] zynqmp-pinctrl ff180000.pinctrl: Invalid IO Standard requested for pin 72
[    3.172605] zynqmp-pinctrl ff180000.pinctrl: Invalid IO Standard requested for pin 73
[    3.180417] zynqmp-pinctrl ff180000.pinctrl: Invalid IO Standard requested for pin 74
[    3.188247] zynqmp-pinctrl ff180000.pinctrl: Invalid IO Standard requested for pin 75
[    3.202623] zynqmp-pinctrl ff180000.pinctrl: invalid group "i2c0_8_grp" for function "i2c1"
[    3.210927] zynqmp-pinctrl ff180000.pinctrl: function 'gpio1' not supported
[    3.217843] zynqmp-pinctrl ff180000.pinctrl: invalid function gpio1 in map table
[    3.225225] zynqmp-pinctrl ff180000.pinctrl: function 'gpio1' not supported
[    3.232163] zynqmp-pinctrl ff180000.pinctrl: invalid function gpio1 in map table
[    3.239669] zynqmp-pinctrl ff180000.pinctrl: Invalid IO Standard requested for pin 34
[    3.247484] zynqmp-pinctrl ff180000.pinctrl: Invalid IO Standard requested for pin 35
[    3.255442] cdns-i2c ff020000.i2c: 400 kHz mmio ff020000 irq 25
[    3.261793] zynqmp-pinctrl ff180000.pinctrl: function 'gpio1' not supported
[    3.268686] zynqmp-pinctrl ff180000.pinctrl: invalid function gpio1 in map table
[    3.276070] zynqmp-pinctrl ff180000.pinctrl: function 'gpio1' not supported
[    3.283002] zynqmp-pinctrl ff180000.pinctrl: invalid function gpio1 in map table
[    3.290540] zynqmp-pinctrl ff180000.pinctrl: Invalid IO Standard requested for pin 36
[    3.298349] zynqmp-pinctrl ff180000.pinctrl: Invalid IO Standard requested for pin 37
[    3.306295] cdns-i2c ff030000.i2c: 400 kHz mmio ff030000 irq 26
[    3.360089] mmc0: SDHCI controller on ff170000.sdhci [ff170000.sdhci] using ADMA 64-bit
[    3.368239] hctosys: unable to open rtc device (rtc0)
[    3.373397] clk: Not disabling unused clocks
[    3.377621] ALSA device list:
[    3.380538]   No soundcards found.
[    3.386507] RAMDISK: gzip image found at block 0
[    4.685423] EXT4-fs (ram0): couldn't mount as ext3 due to feature incompatibilities
[    4.693872] EXT4-fs (ram0): mounted filesystem without journal. Opts: (null)
[    4.700915] VFS: Mounted root (ext4 filesystem) on device 1:0.
[    4.706979] devtmpfs: mounted
[    4.710103] Freeing unused kernel memory: 512K (ffffffc000c30000 - ffffffc000cb0000)
INIT: version 2.88 booting
mount: mounting devtmpfs on /dev failed: Device or resource busy
Starting Bootlog daemon: bootlogd.
Starting Monitor-ipsig daemon: monitor-ipsig.
[    4.829263] EXT4-fs (ram0): re-mounted. Opts: block_validity,delalloc,barrier,user_xattr,acl
[    4.848301] random: dd: uninitialized urandom read (512 bytes read)
check mouted config
mounting config
[    4.871494] jffs2: CLEANMARKER node found at 0x00000000 has totlen 0xc != normal 0x0
[    4.890437] jffs2: Empty flash at 0x00000080 ends at 0x00000800
[    4.913951] random: fast init done
[    4.950292] jffs2: notice: (1587) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found.
Starting syslogd/klogd: done
/etc/init.d/rc: /etc/rcS.d/S37populate-volatile.sh: line 214: can't create //var/tmp/tmpdefined.1545: nonexistent directory
/etc/init.d/rc: /etc/rcS.d/S37populate-volatile.sh: line 214: can't create //var/tmp/tmp.1545: nonexistent directory
/etc/init.d/rc: /etc/rcS.d/S37populate-volatile.sh: line 214: can't create //var/tmp/tmpcombined.1545: nonexistent directory
cat: can't open '//var/tmp/tmpdefined.1545': Not a directory
cat: can't open '//var/tmp/tmp.1545': Not a directory
cat: can't open '//var/tmp/tmpcombined.1545': Not a directory
cat: can't open '//var/tmp/tmpdefined.1[    5.200187] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
cat: can't open '//var/tmp/tmpcombined.1545': Not[    5.225032] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
a directory
rm: can't stat '//var/tmp/tmp.1545': Not a directory
rm: can't stat '//var/tmp/tmpdefined.1545': Not a directory
rm: can't stat '//var/tmp/tmpcombined.1545': Not a directory
killall: udhcpc: no process killed
udhcpc (v1.20.2) started
Sending discover...
Sending discover...
[    8.308402] macb ff0d0000.ethernet eth0: link up (1000/Full)
[    8.314012] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Sending select for 192.168.31.64...
Lease of 192.168.31.64 obtained, lease time 120
/etc/udhcpc.d/50default: Adding DNS 192.168.31.1
1 Jan 00:00:17 ntpdate[1802]: no server suitable for synchronization found
Starting Dropbear SSH server: dropbear.
Starting ntpd: done
Starting Avahi Daemon: avahi-daemon.
Starting Lighttpd Web Server: lighttpd.
Starting Cgminer daemon: /etc/init.d/rc: /etc/rcS.d/S70cgminer.sh: line 202: can't create /tmp/pic_mac: nonexistent directory
Starting Monitor-recobtn daemon: monitor-recobtn.
Collected errors:
INIT: Entering runlevel: 5g temp dir /tmp/opk
Stopping Bootlog daemon: bootlogd.
.---O---.
|       |                  .-.           o o
|       |     | __  |  ---'| '--.|  .-'|     |     |
The Angstrom Distribution antMiner ttyPS0
Angstrom v2013.06 - Kernel 4.9.0+
antMiner login: Restarting Cgminer daemon: killall: cgminer: no process killed
E7好控制板UART打印信息.txt
18.23 KB, 下载次数: 0, 下载积分: 金币 1
售价: 10 金币  [记录]  [购买]
