芯片识别0,这个要先检查维修哪里
查看2127 | 回复0 | 2024-3-25 11:09:51 | 显示全部楼层 |阅读模式
CPU: 0 PID: 717 Comm: ubiattach Not tainted 4.6.0-xilinx-gff8137b-dirty #25
Hardware name: Xilinx Zynq Platform
[<c010e718>] (unwind_backtrace) from [<c010a8d0>] (show_stack+0x10/0x14)
[<c010a8d0>] (show_stack) from [<c02fcea4>] (dump_stack+0x84/0xa4)
[<c02fcea4>] (dump_stack) from [<c0405d64>] (ubi_io_read+0x1d4/0x2a8)
[<c0405d64>] (ubi_io_read) from [<c0406050>] (ubi_io_read_ec_hdr+0x68/0x1cc)
[<c0406050>] (ubi_io_read_ec_hdr) from [<c040a1d4>] (ubi_attach+0x130/0x1194)
[<c040a1d4>] (ubi_attach) from [<c0400b28>] (ubi_attach_mtd_dev+0x62c/0xaf8)
[<c0400b28>] (ubi_attach_mtd_dev) from [<c0401ff8>] (ctrl_cdev_ioctl+0xf0/0x1ec)
[<c0401ff8>] (ctrl_cdev_ioctl) from [<c01d6b88>] (vfs_ioctl+0x20/0x34)
[<c01d6b88>] (vfs_ioctl) from [<c01d7488>] (do_vfs_ioctl+0x7d8/0x8b0)
[<c01d7488>] (do_vfs_ioctl) from [<c01d7594>] (SyS_ioctl+0x34/0x5c)
[<c01d7594>] (SyS_ioctl) from [<c0106f00>] (ret_fast_syscall+0x0/0x3c)
ubi1 warning: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 576:512, read only 512 bytes, retry
ubi1 error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 576:512, read 512 bytes
[<c0405d64>] (ubi_io_read) from [<c0406220>] (ubi_io_read_vid_hdr+0x6c/0x1d8)
[<c0406220>] (ubi_io_read_vid_hdr) from [<c040a290>] (ubi_attach+0x1ec/0x1194)
[<c040a290>] (ubi_attach) from [<c0400b28>] (ubi_attach_mtd_dev+0x62c/0xaf8)
ubi1 warning: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 595:0, read only 64 bytes, retry
ubi1 error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 595:0, read 64 bytes
ubi1 warning: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 595:512, read only 512 bytes, retry
ubi1 error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 595:512, read 512 bytes
ubi1 warning: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 632:0, read only 64 bytes, retry
ubi1 error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 632:0, read 64 bytes
ubi1 warning: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 632:512, read only 512 bytes, retry
ubi1 error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 632:512, read 512 bytes
ubi1: scanning is finished
ubi1: attached mtd5 (name "reserve1", size 128 MiB)
ubi1: PEB size: 131072 bytes (128 KiB), LEB size: 129024 bytes
ubi1: min./max. I/O unit sizes: 2048/2048, sub-page size 512
ubi1: VID header offset: 512 (aligned 512), data offset: 2048
ubi1: good PEBs: 1019, bad PEBs: 5, corrupted PEBs: 0
ubi1: user volume: 1, internal volumes: 1, max. volumes count: 128
ubi1: max/mean erase counter: 19622/17518, WL threshold: 4096, image sequence number: 1857823607
ubi1: available PEBs: 0, total reserved PEBs: 1019, PEBs reserved for bad PEB handling: 35
ubi1: background thread "ubi_bgt1d" started, PID 720
UBIFS (ubi1:0): background thread "ubifs_bgt1_0" started, PID 723
UBIFS (ubi1:0): UBIFS: mounted UBI device 1, volume 0, name "reserve1"
CPU: 0 PID: 720 Comm: ubi_bgt1d Not tainted 4.6.0-xilinx-gff8137b-dirty #25
[<c0406220>] (ubi_io_read_vid_hdr) from [<c0408280>] (wear_leveling_worker+0x1e0/0x6a0)
[<c0408280>] (wear_leveling_worker) from [<c0407770>] (do_work+0xcc/0x100)
[<c0407770>] (do_work) from [<c0408dc8>] (ubi_thread+0x100/0x190)
[<c0408dc8>] (ubi_thread) from [<c0132960>] (kthread+0xdc/0xf0)
[<c0132960>] (kthread) from [<c0106fb8>] (ret_from_fork+0x14/0x3c)
ubi1: scrubbed PEB 595 (LEB 0:824), data moved to PEB 344
ubi1: scrubbed PEB 576 (LEB 0:151), data moved to PEB 693
ubi1: scrubbed PEB 632 (LEB 0:211), data moved to PEB 565
UBIFS (ubi1:0): LEB size: 129024 bytes (126 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
UBIFS (ubi1:0): FS size: 125024256 bytes (119 MiB, 969 LEBs), journal size 6322176 bytes (6 MiB, 49 LEBs)
UBIFS (ubi1:0): reserved for root: 4952683 bytes (4836 KiB)
UBIFS (ubi1:0): media format: w4/r0 (latest is w4/r0), UUID B08F051B-2357-4CFE-957E-608EF71E3E17, small LPT model
IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
macb e000b000.ethernet eth0: unable to generate target frequency: 25000000 Hz
macb e000b000.ethernet eth0: link up (100/Full)
IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
In axi fpga driver!
request_mem_region OK!
AXI fpga dev virtual address is 0xcfb5c000
*base_vir_addr = 0xb023
In fpga mem driver!
fpga mem virtual address is 0xd2000000
2024-03-25 03:02:53:thread.c:1555:create_bitmain_soc_init_thread: create thread
2024-03-25 03:02:53:driver-btm-api.c:682:init_freq_mode: This is scan-user version
2024-03-25 03:02:53:driver-btm-api.c:2518:bitmain_soc_init: Miner compile time: Fri Jan  8 22:35:06 CST 2021 type: Antminer T17e
2024-03-25 03:02:53:driver-btm-api.c:2519:bitmain_soc_init: commit version: 37668c9 2021-01-08 18:20:11, build by: jenkins 2021-01-08 22:39:58
2024-03-25 03:02:53:driver-btm-api.c:2520:bitmain_soc_init: opt_multi_version     = 1
2024-03-25 03:02:53:driver-btm-api.c:2521:bitmain_soc_init: opt_bitmain_ab        = 1
2024-03-25 03:02:53:driver-btm-api.c:2522:bitmain_soc_init: mid_auto_gen          = 0
2024-03-25 03:02:53:driver-btm-api.c:2523:bitmain_soc_init: work_mode             = 0
2024-03-25 03:02:53:driver-btm-api.c:2524:bitmain_soc_init: power_feedback_en     = true
2024-03-25 03:02:53:driver-btm-api.c:2067:show_sn: no SN got, please write SN to /config/sn
2024-03-25 03:02:53:driver-btm-api.c:1384:miner_device_init: Detect 256MB control board of XILINX
2024-03-25 03:02:53:driver-btm-api.c:1325:init_fan_parameter: fan_eft : 0  fan_pwm : 0
2024-03-25 03:02:59:driver-btm-api.c:1309:init_miner_version: miner ID : 8034e42a18c08854
2024-03-25 03:02:59:driver-btm-api.c:1315:init_miner_version: FPGA Version = 0xB023
2024-03-25 03:03:01:auto_adapt.c:100:_get_board_info: chain[0] board bin: 1, chip bin: 1, chip ft: A4V4, chip version: AB
2024-03-25 03:03:01:driver-btm-api.c:2164:get_calibration_voltage: calibration voltage flag is error data.
2024-03-25 03:03:01 voltage[0] = 1840
2024-03-25 03:03:01:auto_adapt.c:273:is_sweep_failed_before: open sweep tag failed
voltage_ref = 1840
2100  2100  2100  2100  2100  2100
2100  2100  2100  2100  2100  2060
2100  2100  2100  2100  2070  2020
2070  2060  2060  2050  2020  1970
2020  2010  2010  2000  1980  1920
1980  1970  1960  1950  1910  1860
2024-03-25 03:03:01:thread.c:1523:create_read_nonce_reg_thread: create thread
2024-03-25 03:03:01:driver-btm-api.c:698:dump_pcb_bom_version: Chain [0] PCB Version: 0x010a
2024-03-25 03:03:01:driver-btm-api.c:699:dump_pcb_bom_version: Chain [0] BOM Version: 0x0100
2024-03-25 03:03:07:driver-btm-api.c:2344:bitmain_board_init: Fan check passed.
2024-03-25 03:03:08:board.c:81:jump_and_app_check_restore_pic: chain[0] PIC jump to app
2024-03-25 03:03:10:board.c:94:jump_and_app_check_restore_pic: Check chain[0] PIC fw version=0x88
2024-03-25 03:03:10:thread.c:1518:create_pic_heart_beat_thread: create thread
2024-03-25 03:03:12:power_api.c:241:power_init: power type version: 0x0042
2024-03-25 03:03:14:power_api.c:259:power_init: Power init:
2024-03-25 03:03:14:power_api.c:260:power_init: current_voltage_raw     = 1801
2024-03-25 03:03:14:power_api.c:261:power_init: highest_voltage_raw     = 2000
2024-03-25 03:03:14:power_api.c:262:power_init: working_voltage_raw     = 1800
2024-03-25 03:03:14:power_api.c:263:power_init: higher_voltage_raw      = 1850
2024-03-25 03:03:14:power_api.c:264:power_init: check_asic_voltage_raw  = 1800
2024-03-25 03:03:14:driver-btm-api.c:2354:bitmain_board_init: Enter 60s sleep to make sure power release finish.
2024-03-25 03:04:16:driver-btm-api.c:1123:check_asic_number_until_volt_balance: THIS is No.1 time boost asic:
2024-03-25 03:04:16:power_api.c:334:modify_check_asic_voltage: check_asic_voltage_raw  = 1800
2024-03-25 03:04:19:power_api.c:298:set_to_check_asic_voltage_by_steps: Set to voltage raw 1800, step by step.
2024-03-25 03:04:23:uart.c:69:set_baud: set UART baud to 115200
chain 0, IO_DRIVE_STRENGTH_CONFIGURATION reg = 0x 7777777
2024-03-25 03:04:27:driver-btm-api.c:1035:check_asic_number_with_power_on: Chain[0]: find 0 asic, times 0
2024-03-25 03:04:28:board.c:81:jump_and_app_check_restore_pic: chain[0] PIC jump to app
2024-03-25 03:04:31:board.c:94:jump_and_app_check_restore_pic: Check chain[0] PIC fw version=0x88
2024-03-25 03:04:31:power_api.c:334:modify_check_asic_voltage: check_asic_voltage_raw  = 1900
2024-03-25 03:04:31:power_api.c:298:set_to_check_asic_voltage_by_steps: Set to voltage raw 1900, step by step.
2024-03-25 03:04:43:driver-btm-api.c:1035:check_asic_number_with_power_on: Chain[0]: find 0 asic, times 1
2024-03-25 03:04:44:board.c:81:jump_and_app_check_restore_pic: chain[0] PIC jump to app
2024-03-25 03:04:46:board.c:94:jump_and_app_check_restore_pic: Check chain[0] PIC fw version=0x88
2024-03-25 03:04:46:power_api.c:334:modify_check_asic_voltage: check_asic_voltage_raw  = 2000
2024-03-25 03:04:46:power_api.c:298:set_to_check_asic_voltage_by_steps: Set to voltage raw 2000, step by step.
2024-03-25 03:04:59:driver-btm-api.c:1035:check_asic_number_with_power_on: Chain[0]: find 0 asic, times 2
2024-03-25 03:05:00:board.c:81:jump_and_app_check_restore_pic: chain[0] PIC jump to app
2024-03-25 03:05:02:board.c:94:jump_and_app_check_restore_pic: Check chain[0] PIC fw version=0x88
2024-03-25 03:05:02:power_api.c:334:modify_check_asic_voltage: check_asic_voltage_raw  = 2100
2024-03-25 03:05:02:power_api.c:298:set_to_check_asic_voltage_by_steps: Set to voltage raw 2100, step by step.
2024-03-25 03:05:14:driver-btm-api.c:1035:check_asic_number_with_power_on: Chain[0]: find 0 asic, times 3
2024-03-25 03:05:15:board.c:81:jump_and_app_check_restore_pic: chain[0] PIC jump to app
2024-03-25 03:05:17:board.c:94:jump_and_app_check_restore_pic: Check chain[0] PIC fw version=0x88
2024-03-25 03:05:17:power_api.c:334:modify_check_asic_voltage: check_asic_voltage_raw  = 1800
2024-03-25 03:05:17:power_api.c:298:set_to_check_asic_voltage_by_steps: Set to voltage raw 1800, step by step.
2024-03-25 03:05:33:driver-btm-api.c:1217:check_asic_number: Chain 0 only find 0 asic, will power off hash board 0
2024-03-25 03:05:34:driver-btm-api.c:247:set_miner_status: ERROR_SOC_INIT
2024-03-25 03:05:34:driver-btm-api.c:176:stop_mining: stop mining: soc init failed!
2024-03-25 03:05:34:thread.c:1595:cancel_read_nonce_reg_thread: cancel thread
2024-03-25 03:05:34:driver-btm-api.c:147:killall_hashboard: ****power off hashboard****
