求救啊铁子们..L3+后台日志
查看3232 | 回复1 | 2022-10-25 16:35:46 | 显示全部楼层 |阅读模式
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Initializing cgroup subsys cpu
[    0.000000] Linux version 3.8.13 (xxl@armdev01) (gcc version 4.7.4 20130626 (prerelease) (Linaro GCC 4.7-2013.07) ) #22 SMP Tue Dec 2 15:26:11 CST 2014
[    0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=50c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine: Generic AM33XX (Flattened Device Tree), model: TI AM335x BeagleBone
[    0.000000] Memory policy: ECC disabled, Data cache writeback
[    0.000000] On node 0 totalpages: 65280
[    0.000000] free_area_init_node: node 0, pgdat c06cb100, node_mem_map c0726000
[    0.000000]   Normal zone: 512 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 64768 pages, LIFO batch:15
[    0.000000] AM335X ES1.0 (neon )
[    0.000000] PERCPU: Embedded 8 pages/cpu @c0933000 s9408 r8192 d15168 u32768
[    0.000000] pcpu-alloc: s9408 r8192 d15168 u32768 alloc=8*4096
[    0.000000] pcpu-alloc: [0] 0
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 64768
[    0.000000] Kernel command line: console=ttyO0,115200n8 init=/sbin/init
[    0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[    0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[    0.000000] __ex_table already sorted, skipping sort
[    0.000000] allocated 524288 bytes of page_cgroup
[    0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[    0.000000] Memory: 255MB = 255MB total
[    0.000000] Memory: 238956k/238956k available, 23188k reserved, 0K highmem
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     vmalloc : 0xd0800000 - 0xff000000   ( 744 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xd0000000   ( 256 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf800000 - 0xbfe00000   (   6 MB)
[    0.000000]       .text : 0xc0008000 - 0xc0612cf0   (6188 kB)
[    0.000000]       .init : 0xc0613000 - 0xc06554c0   ( 266 kB)
[    0.000000]       .data : 0xc0656000 - 0xc06cc020   ( 473 kB)
[    0.000000]        .bss : 0xc06cc020 - 0xc0725e3c   ( 360 kB)
[    0.000000] Hierarchical RCU implementation.
[    0.000000]         RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
[    0.000000] Total of 128 interrupts on 1 active controller
[    0.000000] OMAP clockevent source: GPTIMER1 at 24000000 Hz
[    0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[    0.000000] OMAP clocksource: GPTIMER2 at 24000000 Hz
[    0.000000] Console: colour dummy device 80x30
[    0.000351] Calibrating delay loop... 545.07 BogoMIPS (lpj=531968)
[    0.015436] pid_max: default: 32768 minimum: 301
[    0.015667] Security Framework initialized
[    0.015762] Mount-cache hash table entries: 512
[    0.024585] Initializing cgroup subsys cpuacct
[    0.024618] Initializing cgroup subsys memory
[    0.024682] Initializing cgroup subsys blkio
[    0.024816] CPU: Testing write buffer coherency: ok
[    0.025391] CPU0: thread -1, cpu 0, socket -1, mpidr 0
[    0.025466] Setting up static identity map for 0x8038c820 - 0x8038c86c
[    0.026800] Brought up 1 CPUs
[    0.026823] SMP: Total of 1 processors activated (545.07 BogoMIPS).
[    0.028128] devtmpfs: initialized
[    0.092525] pinctrl core: initialized pinctrl subsystem
[    0.092741] rstctl core: initialized rstctl subsystem
[    0.093234] regulator-dummy: no parameters
[    0.093811] NET: Registered protocol family 16
[    0.094520] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.104194] pinctrl-single 44e10800.pinmux: prop pinctrl-0 index 0 invalid phandle
[    0.104377] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[    0.105473] platform 49000000.edma: alias fck already exists
[    0.105507] platform 49000000.edma: alias fck already exists
[    0.105535] platform 49000000.edma: alias fck already exists
[    0.106685] gpiochip_add: registered GPIOs 0 to 31 on device: gpio
[    0.106866] OMAP GPIO hardware version 0.1
[    0.108275] gpiochip_add: registered GPIOs 32 to 63 on device: gpio
[    0.109595] gpiochip_add: registered GPIOs 64 to 95 on device: gpio
[    0.110909] gpiochip_add: registered GPIOs 96 to 127 on device: gpio
[    0.111545] of_get_named_gpio_flags exited with status 52
[    0.111577] gpio-rctrl rstctl.3: loaded OK
[    0.116684] omap-gpmc 50000000.gpmc: GPMC revision 6.0
[    0.119897] hw-breakpoint: debug architecture 0x4 unsupported.
[    0.122075] cpsw.0: No hwaddr in dt. Using 40:bd:32:23:3f:d2 from efuse
[    0.122108] cpsw.1: No hwaddr in dt. Using 40:bd:32:23:3f:d4 from efuse
[    0.137658] bio: create slab <bio-0> at 0
[    0.149780] edma-dma-engine edma-dma-engine.0: TI EDMA DMA engine driver
[    0.150019] of_get_named_gpio_flags: can't parse gpios property
[    0.150311] vmmcsd_fixed: 3300 mV
[    0.153418] SCSI subsystem initialized
[    0.153874] usbcore: registered new interface driver usbfs
[    0.153987] usbcore: registered new interface driver hub
[    0.154323] usbcore: registered new device driver usb
[    0.156434] omap_i2c 4819c000.i2c: bus 0 rev0.11 at 100 kHz
[    0.156468] omap_i2c 4819c000.i2c: unable to select pin group
[    0.156661] media: Linux media interface: v0.10
[    0.156755] Linux video capture interface: v2.00
[    0.156871] pps_core: LinuxPPS API ver. 1 registered
[    0.156888] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.157600] Advanced Linux Sound Architecture Driver Initialized.
[    0.158790] Switching to clocksource gp_timer
[    0.176782] NET: Registered protocol family 2
[    0.177774] TCP established hash table entries: 2048 (order: 2, 16384 bytes)
[    0.177863] TCP bind hash table entries: 2048 (order: 3, 40960 bytes)
[    0.177952] TCP: Hash tables configured (established 2048 bind 2048)
[    0.178043] TCP: reno registered
[    0.178070] UDP hash table entries: 256 (order: 1, 12288 bytes)
[    0.178116] UDP-Lite hash table entries: 256 (order: 1, 12288 bytes)
[    0.178611] NET: Registered protocol family 1
[    0.179200] RPC: Registered named UNIX socket transport module.
[    0.179222] RPC: Registered udp transport module.
[    0.179236] RPC: Registered tcp transport module.
[    0.179250] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.179638] Trying to unpack rootfs image as initramfs...
[    1.913438] Freeing initrd memory: 11960K
[    1.914125] CPU PMU: probing PMU on CPU 0
[    1.914157] hw perfevents: enabled with ARMv7 Cortex-A8 PMU driver, 5 counters available
[    1.914689] omap2_mbox_probe: platform not supported
[    1.918537] VFS: Disk quotas dquot_6.5.2
[    1.918871] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    1.920180] NFS: Registering the id_resolver key type
[    1.920273] Key type id_resolver registered
[    1.920290] Key type id_legacy registered
[    1.920357] jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
[    1.920869] msgmni has been set to 490
[    1.923665] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[    1.923691] io scheduler noop registered
[    1.923708] io scheduler deadline registered
[    1.923766] io scheduler cfq registered (default)
[    1.927807] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    1.930276] omap_uart 44e09000.serial: did not get pins for uart0 error: -19
[    1.930649] 44e09000.serial: ttyO0 at MMIO 0x44e09000 (irq = 88) is a OMAP UART0
[    2.591478] console [ttyO0] enabled
[    2.596004] 48022000.serial: ttyO1 at MMIO 0x48022000 (irq = 89) is a OMAP UART1
[    2.604704] 48024000.serial: ttyO2 at MMIO 0x48024000 (irq = 90) is a OMAP UART2
[    2.613339] 481a8000.serial: ttyO4 at MMIO 0x481a8000 (irq = 61) is a OMAP UART4
[    2.621997] 481aa000.serial: ttyO5 at MMIO 0x481aa000 (irq = 62) is a OMAP UART5
[    2.630980] [drm] Initialized drm 1.1.0 20060810
[    2.649662] brd: module loaded
[    2.659944] loop: module loaded
[    2.664129] bone-capemgr bone_capemgr.8: Failed to find baseboard eeprom node
[    2.674075] nand_get_flash_type: 2c,da against 2c,da
[    2.679601] ONFI param page 0 valid
[    2.683275] ONFI flash detected
[    2.686596] NAND device: Manufacturer ID: 0x2c, Chip ID: 0xda (Micron MT29F2G08ABAEAWP), 256MiB, page size: 2048, OOB size: 64
[    2.698508] omap2-nand: detected x8 NAND flash
[    2.703173] nand: using OMAP_ECC_BCH8_CODE_HW ECC scheme
[    2.708756] omap2-nand: using custom ecc layout
[    2.713623] 10 ofpart partitions found on MTD device omap2-nand.0
[    2.720016] Creating 10 MTD partitions on "omap2-nand.0":
[    2.725695] 0x000000000000-0x000000020000 : "spl"
[    2.732495] 0x000000020000-0x000000040000 : "spl_backup1"
[    2.739974] 0x000000040000-0x000000060000 : "spl_backup2"
[    2.747380] 0x000000060000-0x000000080000 : "spl_backup3"
[    2.754798] 0x000000080000-0x000000240000 : "u-boot"
[    2.763050] 0x000000240000-0x000000260000 : "bootenv"
[    2.769949] 0x000000260000-0x000000280000 : "fdt"
[    2.776583] 0x000000280000-0x000000780000 : "kernel"
[    2.787559] 0x000000800000-0x000001c00000 : "root"
[    2.811055] 0x000001c00000-0x000003000000 : "config"
[    2.834864] OneNAND driver initializing
[    2.840596] usbcore: registered new interface driver asix
[    2.846434] usbcore: registered new interface driver cdc_ether
[    2.852678] usbcore: registered new interface driver smsc95xx
[    2.858795] usbcore: registered new interface driver net1080
[    2.864820] usbcore: registered new interface driver cdc_subset
[    2.871114] usbcore: registered new interface driver zaurus
[    2.877119] usbcore: registered new interface driver cdc_ncm
[    2.883886] usbcore: registered new interface driver cdc_acm
[    2.889840] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    2.898218] Initializing USB Mass Storage driver...
[    2.903456] usbcore: registered new interface driver usb-storage
[    2.909758] USB Mass Storage support registered.
[    2.914830] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
[    2.921541] musb-hdrc musb-hdrc.0.auto: pdev->id = 0
[    2.926787] musb-hdrc musb-hdrc.0.auto: drivers/usb/musb/musb_dsps.c:468 dsps_musb_init: OK
[    2.935558] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
[    2.935579] musb-hdrc: MHDRC RTL version 2.0
[    2.935594] musb-hdrc: setup fifo_mode 4
[    2.935622] musb-hdrc: 28/31 max ep, 16384/16384 memory
[    2.935770] musb-hdrc musb-hdrc.0.auto: *** mode=3
[    2.940814] musb-hdrc musb-hdrc.0.auto: *** power=250
[    2.946831] musb-hdrc musb-hdrc.1.auto: pdev->id = 1
[    2.952087] musb-hdrc musb-hdrc.1.auto: drivers/usb/musb/musb_dsps.c:468 dsps_musb_init: OK
[    2.960857] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
[    2.960877] musb-hdrc: MHDRC RTL version 2.0
[    2.960892] musb-hdrc: setup fifo_mode 4
[    2.960914] musb-hdrc: 28/31 max ep, 16384/16384 memory
[    2.961052] musb-hdrc musb-hdrc.1.auto: *** mode=1
[    2.966100] musb-hdrc musb-hdrc.1.auto: *** power=250
[    2.971408] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[    2.977778] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 1
[    2.986022] musb-hdrc musb-hdrc.1.auto: supports USB remote wakeup
[    2.986126] usb usb1: default language 0x0409
[    2.986184] usb usb1: udev 1, busnum 1, minor = 0
[    2.986208] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    2.993335] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.000929] usb usb1: Product: MUSB HDRC host driver
[    3.006145] usb usb1: Manufacturer: Linux 3.8.13 musb-hcd
[    3.011811] usb usb1: SerialNumber: musb-hdrc.1.auto
[    3.018013] usb usb1: usb_probe_device
[    3.018043] usb usb1: configuration #1 chosen from 1 choice
[    3.018115] usb usb1: adding 1-0:1.0 (config #1, interface 0)
[    3.018377] hub 1-0:1.0: usb_probe_interface
[    3.018400] hub 1-0:1.0: usb_probe_interface - got id
[    3.018429] hub 1-0:1.0: USB hub found
[    3.022424] hub 1-0:1.0: 1 port detected
[    3.026561] hub 1-0:1.0: standalone hub
[    3.026581] hub 1-0:1.0: individual port power switching
[    3.026599] hub 1-0:1.0: no over-current protection
[    3.026616] hub 1-0:1.0: Single TT
[    3.026638] hub 1-0:1.0: TT requires at most 8 FS bit times (666 ns)
[    3.026658] hub 1-0:1.0: power on to power good time: 10ms
[    3.026713] hub 1-0:1.0: local power source is good
[    3.026828] hub 1-0:1.0: enabling power on all ports
[    3.027900] mousedev: PS/2 mouse device common for all mice
[    3.035897] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0
[    3.043682] i2c /dev entries driver
[    3.048724] pps_ldisc: PPS line discipline registered
[    3.054209] Driver for 1-wire Dallas network protocol.
[    3.061469] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[    3.069057] cpuidle: using governor ladder
[    3.073375] cpuidle: using governor menu
[    3.077936] of_get_named_gpio_flags exited with status 6
[    3.077957] of_get_named_gpio_flags: can't parse gpios property
[    3.077973] of_get_named_gpio_flags: can't parse gpios property
[    3.078010] omap_hsmmc mmc.4: of_parse_phandle_with_args of 'reset' failed
[    3.085251] omap_hsmmc mmc.4: Failed to get rstctl; not using any
[    3.092064] edma-dma-engine edma-dma-engine.0: allocated channel for 0:25
[    3.099283] edma-dma-engine edma-dma-engine.0: allocated channel for 0:24
[    3.106605] mmc.4 supply vmmc_aux not found, using dummy regulator
[    3.113564] omap_hsmmc mmc.4: pins are not configured from the driver
[    3.127746] hub 1-0:1.0: state 7 ports 1 chg 0000 evt 0000
[    3.147771] of_get_named_gpio_flags exited with status -517
[    3.147836] platform gpio-leds.7: Driver leds-gpio requests probe deferral
[    3.155617] ledtrig-cpu: registered to indicate activity on CPUs
[    3.162391] edma-dma-engine edma-dma-engine.0: allocated channel for 0:36
[    3.169589] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[    3.177674] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[    3.184017] edma-dma-engine edma-dma-engine.0: allocated channel for 0:5
[    3.191199] edma-dma-engine edma-dma-engine.0: allocated channel for 0:6
[    3.203437] usbcore: registered new interface driver usbhid
[    3.209351] usbhid: USB HID core driver
[    3.216262] TCP: cubic registered
[    3.219786] Initializing XFRM netlink socket
[    3.224366] NET: Registered protocol family 17
[    3.229228] NET: Registered protocol family 15
[    3.234079] Key type dns_resolver registered
[    3.238722] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[    3.246835] ThumbEE CPU extension supported.
[    3.251342] Registering SWP/SWPB emulation handler
[    3.257361] registered taskstats version 1
[    3.263981] of_get_named_gpio_flags exited with status -517
[    3.264055] platform gpio-leds.7: Driver leds-gpio requests probe deferral
[    3.321055] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6
[    3.327467] davinci_mdio 4a101000.mdio: detected phy mask fffffffe
[    3.342028] libphy: 4a101000.mdio: probed
[    3.346348] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver SMSC LAN8710/LAN8720
[    3.356593] Detected MACID = 40:bd:32:23:3f:d2
[    3.361279] cpsw 4a100000.ethernet: NAPI disabled
[    3.366669] of_get_named_gpio_flags exited with status -517
[    3.366734] platform gpio-leds.7: Driver leds-gpio requests probe deferral
[    3.375462] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
[    3.384747] cpu0 supply cpu0 not found, using dummy regulator
[    3.391242] cpufreq_cpu0: failed to scale voltage up: -22
[    3.397060] cpufreq_cpu0: failed to scale voltage up: -22
[    3.409854] ALSA device list:
[    3.413088]   No soundcards found.
[    3.417632] Freeing init memory: 264K
[    3.421689] Failed to execute /init
[    4.431134] jffs2: notice: (122) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found.
[    5.733042] net eth0: initializing cpsw version 1.12 (0)
[    5.742018] net eth0: phy found : id is : 0x7c0f1
[    5.747523] libphy: PHY 4a101000.mdio:01 not found
[    5.752743] net eth0: phy 4a101000.mdio:01 not found on slave 1
[    9.887981] libphy: 4a101000.mdio:00 - Link is Up - 100/Full
[   20.178487] omap_i2c 4819c000.i2c: controller timed out
[   21.184344] omap_i2c 4819c000.i2c: controller timed out
[   22.190190] omap_i2c 4819c000.i2c: controller timed out
[   24.295687] omap_i2c 4819c000.i2c: controller timed out
[   25.301531] omap_i2c 4819c000.i2c: controller timed out
[   26.307414] omap_i2c 4819c000.i2c: controller timed out
[   28.412871] omap_i2c 4819c000.i2c: controller timed out
[   29.418707] omap_i2c 4819c000.i2c: controller timed out
[   30.424662] omap_i2c 4819c000.i2c: controller timed out
[   31.436284] omap_i2c 4819c000.i2c: controller timed out
[   32.442149] omap_i2c 4819c000.i2c: controller timed out
[   33.448060] omap_i2c 4819c000.i2c: controller timed out
[   34.459754] omap_i2c 4819c000.i2c: controller timed out
[   60.854262] omap_i2c 4819c000.i2c: controller timed out
[   61.860125] omap_i2c 4819c000.i2c: controller timed out
[   62.865982] omap_i2c 4819c000.i2c: controller timed out
[   64.971458] omap_i2c 4819c000.i2c: controller timed out
[   65.977293] omap_i2c 4819c000.i2c: controller timed out
[   66.983183] omap_i2c 4819c000.i2c: controller timed out
[   69.088692] omap_i2c 4819c000.i2c: controller timed out
[   70.094490] omap_i2c 4819c000.i2c: controller timed out
[   71.100345] omap_i2c 4819c000.i2c: controller timed out
[   72.106436] omap_i2c 4819c000.i2c: controller timed out
[   73.112062] omap_i2c 4819c000.i2c: controller timed out
[   74.118210] omap_i2c 4819c000.i2c: controller timed out
[   75.123802] omap_i2c 4819c000.i2c: controller timed out
[   86.141351] omap_i2c 4819c000.i2c: controller timed out
[   87.147238] omap_i2c 4819c000.i2c: controller timed out
[   88.153071] omap_i2c 4819c000.i2c: controller timed out
Oct 25 08:32:03 (none) local0.err cgminer: Miner compile time: Tue Apr 23 15:28:43 CST 2019 type: Antminer L3+
Oct 25 08:32:03 (none) local0.warn cgminer: Started cgminer 4.9.0
Oct 25 08:32:03 (none) local0.notice cgminer[370]:  detected at /sys/class/gpio/gpio44/value  chain 3
Oct 25 08:32:03 (none) local0.notice cgminer[370]: detect total chain num 1
Oct 25 08:32:03 (none) local0.notice cgminer[370]: i2c init ok
Oct 25 08:32:22 (none) local0.notice cgminer[370]: in tty_init
Oct 25 08:32:22 (none) local0.notice cgminer[370]: tty_init 3
Oct 25 08:32:22 (none) local0.notice cgminer[370]: Start A New Asic Response.Chain Id:[3]
Oct 25 08:32:22 (none) local0.notice cgminer[370]: open device over
Oct 25 08:32:22 (none) local0.notice cgminer[370]: send cmd to get chip address
Oct 25 08:32:24 (none) local0.notice cgminer[370]: Chain 3 ASIC 0 !!!
Oct 25 08:32:24 (none) local0.notice cgminer[370]: Need to recheck asic num !!!
Oct 25 08:32:44 (none) local0.err cgminer: Miner compile time: Tue Apr 23 15:28:43 CST 2019 type: Antminer L3+
Oct 25 08:32:44 (none) local0.warn cgminer: Started cgminer 4.9.0
Oct 25 08:32:44 (none) local0.notice cgminer[684]:  detected at /sys/class/gpio/gpio44/value  chain 3
Oct 25 08:32:44 (none) local0.notice cgminer[684]: detect total chain num 1
Oct 25 08:32:44 (none) local0.notice cgminer[684]: i2c init ok
Oct 25 08:33:03 (none) local0.notice cgminer[684]: in tty_init
Oct 25 08:33:03 (none) local0.notice cgminer[684]: tty_init 3
Oct 25 08:33:03 (none) local0.notice cgminer[684]: Start A New Asic Response.Chain Id:[3]
Oct 25 08:33:03 (none) local0.notice cgminer[684]: open device over
Oct 25 08:33:03 (none) local0.notice cgminer[684]: send cmd to get chip address
Oct 25 08:33:05 (none) local0.notice cgminer[684]: Chain 3 ASIC 0 !!!
Oct 25 08:33:05 (none) local0.notice cgminer[684]: Need to recheck asic num !!!
Oct 25 08:33:07 (none) local0.notice cgminer[684]: Chain 3 ASIC 0 !!!
Oct 25 08:33:07 (none) local0.notice cgminer[684]: Need to recheck asic num !!!
Oct 25 08:33:09 (none) local0.notice cgminer[684]: Chain 3 ASIC 0 !!!
Oct 25 08:33:09 (none) local0.notice cgminer[684]: Need to recheck asic num !!!
Oct 25 08:33:11 (none) local0.notice cgminer[684]: Chain 3 ASIC 0 !!!
Oct 25 08:33:11 (none) local0.notice cgminer[684]: Need to recheck asic num !!!
Oct 25 08:33:13 (none) local0.notice cgminer[684]: Chain 3 ASIC 0 !!!
Oct 25 08:33:13 (none) local0.notice cgminer[684]: Need to recheck asic num !!!
Oct 25 08:33:15 (none) local0.notice cgminer[684]: Chain 3 ASIC 0 !!!
Oct 25 08:33:15 (none) local0.notice cgminer[684]: frequency = '384'
Oct 25 08:33:15 (none) local0.notice cgminer[684]: dev.timeout = 46
Oct 25 08:33:16 (none) local0.notice cgminer[684]: opt_bitmain_L3_core_temp : 2
feiyanhuayu | 2022-12-20 16:04:13 | 显示全部楼层
3号板 故障 读取0个芯片
