T17良品日志
查看7611 | 回复1 | 2020-7-3 11:51:32 | 显示全部楼层 |阅读模式
Brought up 1 CPUs
SMP: Total of 1 processors activated (666.66 BogoMIPS).
CPU: All CPU(s) started in SVC mode.
devtmpfs: initialized
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
pinctrl core: initialized pinctrl subsystem
NET: Registered protocol family 16
DMA: preallocated 256 KiB pool for atomic coherent allocations
cpuidle: using governor menu
hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 4 bytes.
zynq-ocm f800c000.ps7-ocmc: ZYNQ OCM pool: 256 KiB @ 0xcf880000
vgaarb: loaded
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
media: Linux media interface: v0.10
Linux video capture interface: v2.00
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
PTP clock support registered
EDAC MC: Ver: 3.0.0
Advanced Linux Sound Architecture Driver Initialized.
clocksource: Switched to clocksource arm_global_timer
NET: Registered protocol family 2
TCP established hash table entries: 2048 (order: 1, 8192 bytes)
TCP bind hash table entries: 2048 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
UDP hash table entries: 256 (order: 1, 8192 bytes)
UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
PCI: CLS 0 bytes, default 64
Trying to unpack rootfs image as initramfs...
rootfs image is not initramfs (no cpio magic); looks like an initrd
Freeing initrd memory: 12580K (cceb8000 - cdb01000)
hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
futex hash table entries: 512 (order: 3, 32768 bytes)
workingset: timestamp_bits=28 max_order=16 bucket_order=0
jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
dma-pl330 f8003000.ps7-dma: Loaded driver for PL330 DMAC-241330
dma-pl330 f8003000.ps7-dma:         DBUFF-128x8bytes Num_Chans-8 Num_Peri-4 Num_Events-16
e0000000.serial: ttyPS0 at MMIO 0xe0000000 (irq = 158, base_baud = 6249999) is a xuartps
console [ttyPS0] enabled
xdevcfg f8007000.ps7-dev-cfg: ioremap 0xf8007000 to cf86e000
[drm] Initialized drm 1.1.0 20060810
brd: module loaded
loop: module loaded
CAN device driver interface
gpiod_set_value: invalid GPIO
libphy: MACB_mii_bus: probed
macb e000b000.ethernet eth0: Cadence GEM rev 0x00020118 at 0xe000b000 irq 31 (00:0a:35:00:00:00)
Generic PHY e000b000.etherne:00: attached PHY driver [Generic PHY] (mii_bus:phy_addr=e000b000.etherne:00, irq=-1)
e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci-pci: EHCI PCI platform driver
usbcore: registered new interface driver usb-storage
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
Xilinx Zynq CpuIdle Driver started
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
mmc0: SDHCI controller on e0100000.ps7-sdio [e0100000.ps7-sdio] using ADMA
ledtrig-cpu: registered to indicate activity on CPUs
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
nand: device found, Manufacturer ID: 0xc2, Chip ID: 0xda
nand: Macronix MX30LF2GE8AB
nand: 256 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
Bad block table found at page 131008, version 0x01
Bad block table found at page 130944, version 0x01
nand_read_bbt: bad block at 0x00000ff60000
nand_read_bbt: bad block at 0x00000ff80000
nand_read_bbt: bad block at 0x00000ffa0000
nand_read_bbt: bad block at 0x00000ffc0000
6 ofpart partitions found on MTD device pl35x-nand
Creating 6 MTD partitions on "pl35x-nand":
0x000000000000-0x000002800000 : "BOOT.bin-env-dts-kernel"
0x000002800000-0x000004800000 : "ramfs"
0x000004800000-0x000005000000 : "configs"
0x000005000000-0x000006000000 : "reserve"
0x000006000000-0x000008000000 : "ramfs-bak"
0x000008000000-0x000010000000 : "reserve1"
NET: Registered protocol family 10
sit: IPv6 over IPv4 tunneling driver
NET: Registered protocol family 17
can: controller area network core (rev 20120528 abi 9)
NET: Registered protocol family 29
can: raw protocol (rev 20120528)
can: broadcast manager protocol (rev 20120528 t)
can: netlink gateway (rev 20130117) max_hops=1
zynq_pm_ioremap: no compatible node found for 'xlnx,zynq-ddrc-a05'
zynq_pm_late_init: Unable to map DDRC IO memory.
Registering SWP/SWPB emulation handler
hctosys: unable to open rtc device (rtc0)
ALSA device list:
  No soundcards found.
RAMDISK: gzip image found at block 0
EXT4-fs (ram0): couldn't mount as ext3 due to feature incompatibilities
EXT4-fs (ram0): mounted filesystem without journal. Opts: (null)
VFS: Mounted root (ext4 filesystem) on device 1:0.
devtmpfs: mounted
Freeing unused kernel memory: 1024K (c0a00000 - c0b00000)
EXT4-fs (ram0): re-mounted. Opts: block_validity,delalloc,barrier,user_xattr
random: dd urandom read with 0 bits of entropy available
ubi0: attaching mtd2
ubi0 warning: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 42:0, read only 64 bytes, retry
ubi0 error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 42:0, read 64 bytes
CPU: 0 PID: 705 Comm: ubiattach Not tainted 4.6.0-xilinx-gff8137b-dirty #25
Hardware name: Xilinx Zynq Platform
[<c010e718>] (unwind_backtrace) from [<c010a8d0>] (show_stack+0x10/0x14)
[<c010a8d0>] (show_stack) from [<c02fcea4>] (dump_stack+0x84/0xa4)
[<c02fcea4>] (dump_stack) from [<c0405d64>] (ubi_io_read+0x1d4/0x2a8)
[<c0405d64>] (ubi_io_read) from [<c0406050>] (ubi_io_read_ec_hdr+0x68/0x1cc)
[<c0406050>] (ubi_io_read_ec_hdr) from [<c040a1d4>] (ubi_attach+0x130/0x1194)
[<c040a1d4>] (ubi_attach) from [<c0400b28>] (ubi_attach_mtd_dev+0x62c/0xaf8)
[<c0400b28>] (ubi_attach_mtd_dev) from [<c0401ff8>] (ctrl_cdev_ioctl+0xf0/0x1ec)
[<c0401ff8>] (ctrl_cdev_ioctl) from [<c01d6b88>] (vfs_ioctl+0x20/0x34)
[<c01d6b88>] (vfs_ioctl) from [<c01d7488>] (do_vfs_ioctl+0x7d8/0x8b0)
[<c01d7488>] (do_vfs_ioctl) from [<c01d7594>] (SyS_ioctl+0x34/0x5c)
[<c01d7594>] (SyS_ioctl) from [<c0106f00>] (ret_fast_syscall+0x0/0x3c)
ubi0 warning: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 42:512, read only 512 bytes, retry
ubi0 error: ubi_io_read: error -74 (ECC error) while reading 512 bytes from PEB 42:512, read 512 bytes
[<c0405d64>] (ubi_io_read) from [<c0406220>] (ubi_io_read_vid_hdr+0x6c/0x1d8)
[<c0406220>] (ubi_io_read_vid_hdr) from [<c040a290>] (ubi_attach+0x1ec/0x1194)
[<c040a290>] (ubi_attach) from [<c0400b28>] (ubi_attach_mtd_dev+0x62c/0xaf8)
ubi0: scanning is finished
ubi0: attached mtd2 (name "configs", size 8 MiB)
ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 129024 bytes
ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 512
ubi0: VID header offset: 512 (aligned 512), data offset: 2048
ubi0: good PEBs: 64, bad PEBs: 0, corrupted PEBs: 0
ubi0: user volume: 1, internal volumes: 1, max. volumes count: 128
ubi0: max/mean erase counter: 11/4, WL threshold: 4096, image sequence number: 1658400375
ubi0: available PEBs: 0, total reserved PEBs: 64, PEBs reserved for bad PEB handling: 40
ubi0: background thread "ubi_bgt0d" started, PID 708
UBIFS (ubi0:0): background thread "ubifs_bgt0_0" started, PID 711
UBIFS (ubi0:0): recovery needed
CPU: 0 PID: 708 Comm: ubi_bgt0d Not tainted 4.6.0-xilinx-gff8137b-dirty #25
[<c0406220>] (ubi_io_read_vid_hdr) from [<c0408280>] (wear_leveling_worker+0x1e0/0x6a0)
[<c0408280>] (wear_leveling_worker) from [<c0407770>] (do_work+0xcc/0x100)
[<c0407770>] (do_work) from [<c0408dc8>] (ubi_thread+0x100/0x190)
[<c0408dc8>] (ubi_thread) from [<c0132960>] (kthread+0xdc/0xf0)
[<c0132960>] (kthread) from [<c0106fb8>] (ret_from_fork+0x14/0x3c)
UBIFS (ubi0:0): recovery completed
UBIFS (ubi0:0): UBIFS: mounted UBI device 0, volume 0, name "configs"
UBIFS (ubi0:0): LEB size: 129024 bytes (126 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
UBIFS (ubi0:0): FS size: 1419264 bytes (1 MiB, 11 LEBs), journal size 903169 bytes (0 MiB, 5 LEBs)
UBIFS (ubi0:0): reserved for root: 67035 bytes (65 KiB)
UBIFS (ubi0:0): media format: w4/r0 (latest is w4/r0), UUID 579F3348-1DE7-4ECE-8D71-9E2B0058718D, small LPT model
ubi1: attaching mtd5
ubi1: scanning is finished
ubi1: attached mtd5 (name "reserve1", size 128 MiB)
ubi1: PEB size: 131072 bytes (128 KiB), LEB size: 129024 bytes
ubi1: min./max. I/O unit sizes: 2048/2048, sub-page size 512
ubi1: VID header offset: 512 (aligned 512), data offset: 2048
ubi1: good PEBs: 1019, bad PEBs: 5, corrupted PEBs: 0
ubi1: user volume: 1, internal volumes: 1, max. volumes count: 128
ubi1: max/mean erase counter: 193/85, WL threshold: 4096, image sequence number: 1390910202
ubi1: available PEBs: 0, total reserved PEBs: 1019, PEBs reserved for bad PEB handling: 35
ubi1: background thread "ubi_bgt1d" started, PID 720
UBIFS (ubi1:0): background thread "ubifs_bgt1_0" started, PID 723
UBIFS (ubi1:0): recovery needed
UBIFS (ubi1:0): recovery completed
UBIFS (ubi1:0): UBIFS: mounted UBI device 1, volume 0, name "reserve1"
UBIFS (ubi1:0): LEB size: 129024 bytes (126 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
UBIFS (ubi1:0): FS size: 125024256 bytes (119 MiB, 969 LEBs), journal size 6322176 bytes (6 MiB, 49 LEBs)
UBIFS (ubi1:0): reserved for root: 4952683 bytes (4836 KiB)
UBIFS (ubi1:0): media format: w4/r0 (latest is w4/r0), UUID 400DE64E-7DB4-4352-8F89-C02B55BFDBE2, small LPT model
IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
macb e000b000.ethernet eth0: unable to generate target frequency: 25000000 Hz
macb e000b000.ethernet eth0: link up (100/Full)
IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
In axi fpga driver!
request_mem_region OK!
AXI fpga dev virtual address is 0xcfb40000
*base_vir_addr = 0xab013
In fpga mem driver!
fpga mem virtual address is 0xd2000000
random: nonblocking pool is initialized
2020-07-03 03:35:07 driver-btm-api.c:631:init_freq_mode: This is scan-user version
2020-07-03 03:35:07 driver-btm-api.c:1994:bitmain_soc_init: opt_multi_version     = 1
2020-07-03 03:35:07 driver-btm-api.c:1995:bitmain_soc_init: opt_bitmain_ab        = 1
2020-07-03 03:35:07 driver-btm-api.c:1996:bitmain_soc_init: opt_bitmain_work_mode = 0
2020-07-03 03:35:07 driver-btm-api.c:1997:bitmain_soc_init: Miner compile time: Tue Dec 24 16:13:07 CST 2019 type: Antminer T17
2020-07-03 03:35:07 driver-btm-api.c:1998:bitmain_soc_init: commit version: e93a09b 2019-12-24 16:03:45, build by: lol 2019-12-24 16:19:49
2020-07-03 03:35:07 driver-btm-api.c:1810:show_sn: no SN got, please write SN to /nvdata/sn
2020-07-03 03:35:07 driver-btm-api.c:1135:miner_device_init: Detect 256MB control board of XILINX
2020-07-03 03:35:07 driver-btm-api.c:1083:init_fan_parameter: fan_eft : 0  fan_pwm : 0
2020-07-03 03:35:07 thread.c:789:create_read_nonce_reg_thread: create thread
2020-07-03 03:35:13 driver-btm-api.c:1067:init_miner_version: miner ID : 80126c2a7910481c
2020-07-03 03:35:13 driver-btm-api.c:1073:init_miner_version: FPGA Version = 0xB013
2020-07-03 03:35:15 eeprom.c:436:check_pattern_test_level: L2 board
2020-07-03 03:35:16 eeprom.c:431:check_pattern_test_level: L1 board
2020-07-03 03:35:18 eeprom.c:431:check_pattern_test_level: L1 board
2020-07-03 03:35:18 driver-btm-api.c:705:get_product_id: product_id[0] = 1
2020-07-03 03:35:18 driver-btm-api.c:705:get_product_id: product_id[1] = 1
2020-07-03 03:35:18 driver-btm-api.c:705:get_product_id: product_id[2] = 1
2020-07-03 03:35:18 driver-btm-api.c:1633:get_ccdly_opt: ccdly_opt[0] = 1
2020-07-03 03:35:18 driver-btm-api.c:1633:get_ccdly_opt: ccdly_opt[1] = 1
2020-07-03 03:35:18 driver-btm-api.c:1633:get_ccdly_opt: ccdly_opt[2] = 1
2020-07-03 03:35:18 driver-btm-api.c:1877:bitmain_board_init: g_ccdly_opt = 1
2020-07-03 03:35:18 driver-btm-api.c:644:_set_project_type: project:2
2020-07-03 03:35:18 driver-btm-api.c:674:_set_project_type: Project type: Antminer T17
2020-07-03 03:35:18 driver-btm-api.c:685:dump_pcb_bom_version: Chain [0] PCB Version: 0x0100
2020-07-03 03:35:18 driver-btm-api.c:686:dump_pcb_bom_version: Chain [0] BOM Version: 0x0100
2020-07-03 03:35:18 driver-btm-api.c:685:dump_pcb_bom_version: Chain [1] PCB Version: 0x0100
2020-07-03 03:35:18 driver-btm-api.c:686:dump_pcb_bom_version: Chain [1] BOM Version: 0x0100
2020-07-03 03:35:18 driver-btm-api.c:685:dump_pcb_bom_version: Chain [2] PCB Version: 0x0100
2020-07-03 03:35:18 driver-btm-api.c:686:dump_pcb_bom_version: Chain [2] BOM Version: 0x0100
2020-07-03 03:35:20 driver-btm-api.c:1897:bitmain_board_init: Fan check passed.
2020-07-03 03:35:22 board.c:36:jump_and_app_check_restore_pic: chain[0] PIC jump to app
2020-07-03 03:35:26 board.c:40:jump_and_app_check_restore_pic: Check chain[0] PIC fw version=0xb9
2020-07-03 03:35:27 board.c:36:jump_and_app_check_restore_pic: chain[1] PIC jump to app
2020-07-03 03:35:31 board.c:40:jump_and_app_check_restore_pic: Check chain[1] PIC fw version=0xb9
2020-07-03 03:35:33 board.c:36:jump_and_app_check_restore_pic: chain[2] PIC jump to app
2020-07-03 03:35:36 board.c:40:jump_and_app_check_restore_pic: Check chain[2] PIC fw version=0xb9
2020-07-03 03:35:36 thread.c:784:create_pic_heart_beat_thread: create thread
2020-07-03 03:35:36 power_api.c:55:power_init: power init ...
2020-07-03 03:35:36 driver-btm-api.c:1907:bitmain_board_init: Enter 30s sleep to make sure power release finish.
2020-07-03 03:35:36 power_api.c:46:power_off: init gpio907
2020-07-03 03:36:08 power_api.c:232:set_iic_power_to_highest_voltage: setting to voltage: 17.00 ...
2020-07-03 03:36:14 power_api.c:124:check_voltage_multi: retry time: 0
2020-07-03 03:36:15 power_api.c:86:get_average_voltage: chain[0], voltage is: 21.118388
2020-07-03 03:36:17 power_api.c:86:get_average_voltage: chain[1], voltage is: 20.383623
2020-07-03 03:36:19 power_api.c:86:get_average_voltage: chain[2], voltage is: 19.734580
2020-07-03 03:36:19 power_api.c:97:get_average_voltage: aveage voltage is: 20.412197
2020-07-03 03:36:19 power_api.c:110:check_voltage: target_vol = 17.00, actural_vol = 20.41, more than 1.0v diff.
2020-07-03 03:36:20 power_api.c:124:check_voltage_multi: retry time: 1
2020-07-03 03:36:22 power_api.c:86:get_average_voltage: chain[0], voltage is: 18.785508
2020-07-03 03:36:24 power_api.c:86:get_average_voltage: chain[1], voltage is: 18.216064
2020-07-03 03:36:27 power_api.c:86:get_average_voltage: chain[2], voltage is: 17.273115
2020-07-03 03:36:27 power_api.c:97:get_average_voltage: aveage voltage is: 18.091562
2020-07-03 03:36:27 power_api.c:110:check_voltage: target_vol = 17.00, actural_vol = 18.09, more than 1.0v diff.
2020-07-03 03:36:28 power_api.c:124:check_voltage_multi: retry time: 2
2020-07-03 03:36:30 power_api.c:86:get_average_voltage: chain[0], voltage is: 16.373027
2020-07-03 03:36:33 power_api.c:86:get_average_voltage: chain[1], voltage is: 15.534170
2020-07-03 03:36:35 power_api.c:86:get_average_voltage: chain[2], voltage is: 17.052685
2020-07-03 03:36:35 power_api.c:97:get_average_voltage: aveage voltage is: 16.319961
2020-07-03 03:36:35 power_api.c:182:set_iic_power_by_voltage: now set voltage to : 17.000000
2020-07-03 03:36:35 driver-hash-chip.c:233:dhash_chip_set_baud_v2: chain[0]: chip baud = 115200, chip_divider = 26
2020-07-03 03:36:35 driver-hash-chip.c:233:dhash_chip_set_baud_v2: chain[1]: chip baud = 115200, chip_divider = 26
2020-07-03 03:36:35 driver-hash-chip.c:233:dhash_chip_set_baud_v2: chain[2]: chip baud = 115200, chip_divider = 26
2020-07-03 03:36:35 uart.c:80:set_baud: set fpga_baud = 115200, fpga_divider = 26
2020-07-03 03:36:45 driver-btm-api.c:1010:check_asic_number_with_power_on: Chain[0]: find 30 asic, times 0
2020-07-03 03:36:55 driver-btm-api.c:1010:check_asic_number_with_power_on: Chain[1]: find 30 asic, times 0
2020-07-03 03:37:05 driver-btm-api.c:1010:check_asic_number_with_power_on: Chain[2]: find 30 asic, times 0
2020-07-03 03:37:09 driver-btm-api.c:348:set_order_clock: chain[0]: set order clock, stragegy 3 clock_en=0x1
2020-07-03 03:37:09 driver-btm-api.c:348:set_order_clock: chain[1]: set order clock, stragegy 3 clock_en=0x1
2020-07-03 03:37:09 driver-btm-api.c:348:set_order_clock: chain[2]: set order clock, stragegy 3 clock_en=0x1
2020-07-03 03:37:09 driver-hash-chip.c:490:set_clock_delay_control: core_data = 0xb4
2020-07-03 03:37:09 driver-hash-chip.c:233:dhash_chip_set_baud_v2: chain[0]: chip baud = 3000000, chip_divider = 0
2020-07-03 03:37:09 driver-hash-chip.c:233:dhash_chip_set_baud_v2: chain[1]: chip baud = 3000000, chip_divider = 0
2020-07-03 03:37:09 driver-hash-chip.c:233:dhash_chip_set_baud_v2: chain[2]: chip baud = 3000000, chip_divider = 0
2020-07-03 03:37:09 uart.c:80:set_baud: set fpga_baud = 3000000, fpga_divider = 0
2020-07-03 03:37:09 driver-btm-api.c:1660:check_clock_counter: freq 50 clock_counter_limit 6
2020-07-03 03:37:10 driver-hash-chip.c:233:dhash_chip_set_baud_v2: chain[0]: chip baud = 115200, chip_divider = 26
2020-07-03 03:37:10 driver-hash-chip.c:233:dhash_chip_set_baud_v2: chain[1]: chip baud = 115200, chip_divider = 26
2020-07-03 03:37:10 driver-hash-chip.c:233:dhash_chip_set_baud_v2: chain[2]: chip baud = 115200, chip_divider = 26
2020-07-03 03:37:10 uart.c:80:set_baud: set fpga_baud = 115200, fpga_divider = 26
2020-07-03 03:37:10 voltage[0] = 1690
2020-07-03 03:37:10 voltage[1] = 1690
2020-07-03 03:37:10 voltage[2] = 1690
2020-07-03 03:37:10 power_api.c:140:set_working_voltage: working_voltage = 16.900000
2020-07-03 03:37:11 temperature.c:282:calibrate_temp_sensor_one_chain: Temperature sensor calibration: chain 0 success.
2020-07-03 03:37:13 temperature.c:282:calibrate_temp_sensor_one_chain: Temperature sensor calibration: chain 1 success.
2020-07-03 03:37:14 temperature.c:282:calibrate_temp_sensor_one_chain: Temperature sensor calibration: chain 2 success.
2020-07-03 03:37:14 driver-hash-chip.c:233:dhash_chip_set_baud_v2: chain[0]: chip baud = 6000000, chip_divider = 7
2020-07-03 03:37:14 driver-hash-chip.c:233:dhash_chip_set_baud_v2: chain[1]: chip baud = 6000000, chip_divider = 7
2020-07-03 03:37:14 driver-hash-chip.c:233:dhash_chip_set_baud_v2: chain[2]: chip baud = 6000000, chip_divider = 7
2020-07-03 03:37:14 uart.c:80:set_baud: set fpga_baud = 6000000, fpga_divider = 3
2020-07-03 03:37:16 driver-btm-api.c:248:check_bringup_temp: Bring up temperature is 25
2020-07-03 03:37:16 thread.c:804:create_check_miner_status_thread: create thread
2020-07-03 03:37:16 thread.c:794:create_set_miner_status_thread: create thread
2020-07-03 03:37:16 driver-btm-api.c:581:calculate_timeout: dev->timeout = 392
2020-07-03 03:37:16 thread.c:779:create_temperature_monitor_thread: create thread
2020-07-03 03:37:16 freq_tuning.c:154:freq_tuning_get_max_freq: Max freq of tuning is 760
2020-07-03 03:37:16 power_api.c:379:slowly_set_iic_power_to_custom_voltage: slowly setting to voltage: 17.80 ...
2020-07-03 03:37:54 power_api.c:124:check_voltage_multi: retry time: 0
2020-07-03 03:37:56 power_api.c:86:get_average_voltage: chain[0], voltage is: 17.854804
2020-07-03 03:37:58 power_api.c:86:get_average_voltage: chain[1], voltage is: 17.873174
2020-07-03 03:38:00 power_api.c:86:get_average_voltage: chain[2], voltage is: 17.879297
2020-07-03 03:38:00 power_api.c:97:get_average_voltage: aveage voltage is: 17.869092
2020-07-03 03:38:00 driver-btm-api.c:449:change_freq_one_chain: chain[0] freq: 56 set refdiv: 2, fbdiv: 221, postdiv1: 7, postdiv2: 7, usr divider: 1
2020-07-03 03:38:00 driver-btm-api.c:449:change_freq_one_chain: chain[0] freq: 65 set refdiv: 2, fbdiv: 221, postdiv1: 7, postdiv2: 6, usr divider: 1
2020-07-03 03:38:00 driver-btm-api.c:449:change_freq_one_chain: chain[0] freq: 78 set refdiv: 2, fbdiv: 221, postdiv1: 7, postdiv2: 5, usr divider: 1
2020-07-03 03:38:00 driver-btm-api.c:449:change_freq_one_chain: chain[0] freq: 98 set refdiv: 2, fbdiv: 221, postdiv1: 7, postdiv2: 4, usr divider: 1
2020-07-03 03:38:00 driver-btm-api.c:449:change_freq_one_chain: chain[0] freq: 131 set refdiv: 2, fbdiv: 221, postdiv1: 7, postdiv2: 3, usr divider: 1
2020-07-03 03:38:00 driver-btm-api.c:449:change_freq_one_chain: chain[0] freq: 197 set refdiv: 2, fbdiv: 221, postdiv1: 7, postdiv2: 2, usr divider: 1
2020-07-03 03:38:00 driver-btm-api.c:449:change_freq_one_chain: chain[0] freq: 394 set refdiv: 2, fbdiv: 221, postdiv1: 7, postdiv2: 1, usr divider: 1
2020-07-03 03:38:00 driver-btm-api.c:449:change_freq_one_chain: chain[0] freq: 460 set refdiv: 2, fbdiv: 221, postdiv1: 6, postdiv2: 1, usr divider: 1
2020-07-03 03:38:00 driver-btm-api.c:449:change_freq_one_chain: chain[0] freq: 552 set refdiv: 2, fbdiv: 221, postdiv1: 5, postdiv2: 1, usr divider: 1
2020-07-03 03:38:01 driver-btm-api.c:449:change_freq_one_chain: chain[0] freq: 690 set refdiv: 2, fbdiv: 221, postdiv1: 4, postdiv2: 1, usr divider: 1
2020-07-03 03:38:01 driver-btm-api.c:449:change_freq_one_chain: chain[1] freq: 44 set refdiv: 2, fbdiv: 173, postdiv1: 7, postdiv2: 7, usr divider: 1
2020-07-03 03:38:01 driver-btm-api.c:449:change_freq_one_chain: chain[1] freq: 51 set refdiv: 2, fbdiv: 173, postdiv1: 7, postdiv2: 6, usr divider: 1
2020-07-03 03:38:01 driver-btm-api.c:449:change_freq_one_chain: chain[1] freq: 61 set refdiv: 2, fbdiv: 173, postdiv1: 7, postdiv2: 5, usr divider: 1
2020-07-03 03:38:01 driver-btm-api.c:449:change_freq_one_chain: chain[1] freq: 77 set refdiv: 2, fbdiv: 173, postdiv1: 7, postdiv2: 4, usr divider: 1
2020-07-03 03:38:01 driver-btm-api.c:449:change_freq_one_chain: chain[1] freq: 102 set refdiv: 2, fbdiv: 173, postdiv1: 7, postdiv2: 3, usr divider: 1
2020-07-03 03:38:01 driver-btm-api.c:449:change_freq_one_chain: chain[1] freq: 154 set refdiv: 2, fbdiv: 173, postdiv1: 7, postdiv2: 2, usr divider: 1
2020-07-03 03:38:01 driver-btm-api.c:449:change_freq_one_chain: chain[1] freq: 308 set refdiv: 2, fbdiv: 173, postdiv1: 7, postdiv2: 1, usr divider: 1
2020-07-03 03:38:01 driver-btm-api.c:449:change_freq_one_chain: chain[1] freq: 360 set refdiv: 2, fbdiv: 173, postdiv1: 6, postdiv2: 1, usr divider: 1
2020-07-03 03:38:02 driver-btm-api.c:449:change_freq_one_chain: chain[1] freq: 432 set refdiv: 2, fbdiv: 173, postdiv1: 5, postdiv2: 1, usr divider: 1
2020-07-03 03:38:02 driver-btm-api.c:449:change_freq_one_chain: chain[1] freq: 540 set refdiv: 2, fbdiv: 173, postdiv1: 4, postdiv2: 1, usr divider: 1
2020-07-03 03:38:02 driver-btm-api.c:449:change_freq_one_chain: chain[1] freq: 720 set refdiv: 2, fbdiv: 173, postdiv1: 3, postdiv2: 1, usr divider: 1
2020-07-03 03:38:02 driver-btm-api.c:449:change_freq_one_chain: chain[2] freq: 44 set refdiv: 2, fbdiv: 173, postdiv1: 7, postdiv2: 7, usr divider: 1
2020-07-03 03:38:02 driver-btm-api.c:449:change_freq_one_chain: chain[2] freq: 51 set refdiv: 2, fbdiv: 173, postdiv1: 7, postdiv2: 6, usr divider: 1
2020-07-03 03:38:02 driver-btm-api.c:449:change_freq_one_chain: chain[2] freq: 61 set refdiv: 2, fbdiv: 173, postdiv1: 7, postdiv2: 5, usr divider: 1
2020-07-03 03:38:02 driver-btm-api.c:449:change_freq_one_chain: chain[2] freq: 77 set refdiv: 2, fbdiv: 173, postdiv1: 7, postdiv2: 4, usr divider: 1
2020-07-03 03:38:02 driver-btm-api.c:449:change_freq_one_chain: chain[2] freq: 102 set refdiv: 2, fbdiv: 173, postdiv1: 7, postdiv2: 3, usr divider: 1
2020-07-03 03:38:02 driver-btm-api.c:449:change_freq_one_chain: chain[2] freq: 154 set refdiv: 2, fbdiv: 173, postdiv1: 7, postdiv2: 2, usr divider: 1
2020-07-03 03:38:02 driver-btm-api.c:449:change_freq_one_chain: chain[2] freq: 308 set refdiv: 2, fbdiv: 173, postdiv1: 7, postdiv2: 1, usr divider: 1
2020-07-03 03:38:03 driver-btm-api.c:449:change_freq_one_chain: chain[2] freq: 360 set refdiv: 2, fbdiv: 173, postdiv1: 6, postdiv2: 1, usr divider: 1
2020-07-03 03:38:03 driver-btm-api.c:449:change_freq_one_chain: chain[2] freq: 432 set refdiv: 2, fbdiv: 173, postdiv1: 5, postdiv2: 1, usr divider: 1
2020-07-03 03:38:03 driver-btm-api.c:449:change_freq_one_chain: chain[2] freq: 540 set refdiv: 2, fbdiv: 173, postdiv1: 4, postdiv2: 1, usr divider: 1
2020-07-03 03:38:03 driver-btm-api.c:449:change_freq_one_chain: chain[2] freq: 720 set refdiv: 2, fbdiv: 173, postdiv1: 3, postdiv2: 1, usr divider: 1
2020-07-03 03:38:03 driver-btm-api.c:612:set_timeout: freq 720 final timeout=163
2020-07-03 03:38:03 power_api.c:397:slowly_set_iic_power_to_working_voltage: slowly setting to voltage: 16.90 ...
2020-07-03 03:38:38 power_api.c:124:check_voltage_multi: retry time: 0
2020-07-03 03:38:40 power_api.c:86:get_average_voltage: chain[0], voltage is: 16.936347
2020-07-03 03:38:41 power_api.c:86:get_average_voltage: chain[1], voltage is: 16.985332
2020-07-03 03:38:43 power_api.c:86:get_average_voltage: chain[2], voltage is: 16.991455
2020-07-03 03:38:43 power_api.c:97:get_average_voltage: aveage voltage is: 16.971045
2020-07-03 03:38:43 frequency.c:540:get_current_min_freq: current min freq 690
2020-07-03 03:38:43 driver-btm-api.c:1660:check_clock_counter: freq 690 clock_counter_limit 88
2020-07-03 03:38:44 thread.c:799:create_check_system_status_thread: create thread
2020-07-03 03:38:44 driver-btm-api.c:2113:bitmain_soc_init: Init done!
2020-07-03 03:38:44 driver-btm-api.c:201:set_miner_status: STATUS_INIT
2020-07-03 03:38:49 driver-btm-api.c:201:set_miner_status: STATUS_OKAY
2020-07-03 03:38:55 driver-btm-api.c:1293:dhash_chip_send_job: Version num 4
zqf8604 | 2023-11-5 06:48:32 | 显示全部楼层
感谢分析
